shortcut
Hi
The shortcuts and arrow don’t work …
Hi Blizard,
Which shortcuts do not work for you? Is your keyboards set to a different language other than English?
Alexander
Hi Alexander,
Thank you to answer.
My keyboard is maybe set for french. But for exemple i can’t move with the arrows.
Hi Blizard,
The arrows control the “look” direction of the camera and do not move it around the level, you will have to use the WASD keys for that. But in order to use them you either need to:
  • be in First person mode (activated by clicking on the Walking person in the top toolbar on the left or use the shortcut key " ` "(the button on the left next to the 1 on the numbers row))
  • the the right mouse button pressed and then use the WASD or the arrow keys.
Tell me if this works for you.
Alexander
Thats’s work perfectly, but why it’s need to press the right mousse button ? :wink:
The right mouse button temporarily activates First person mode and then WASD and arrow navigation works. You can additionally use, depending on your Navigation preset (Edit menu>Mouse and Key shortcuts>Navigation tab), orbit, dolly and zoom. You can also change some of the shortcuts(the ones that are greyed out are locked and cannot be changed) to more suitable for you.
Alexander​
