subjetct is topic..
thx
subjetct is topic..
thx
Thanks for report @bs
Which version do you use? I cannot reproduce with 2.6.1. This is what I have tried:
Enable “Safe frame”
Click Screenshot button, see Safe Frame
Change capture resolution
Change window size (rendering resolution)
No crashes.
did you try to change resolution past 6k? maybe this is related to the other high res rtx problem..
Safe frame preview keeps rendering in the window resolution minus areas behind the frame. You are always welcome to send the feedback with logs so we could have a look. Even better if you attach the steps to reproduce the crash ![]()
