Simulation is bigger than the boat...
Hello friends, how are you?
I’m having trouble with my water simulation. I put it to simulate and when I looked at the interactive rendering I saw that the simulation is bigger than the boat. I’ve already tried changing the measurements of the 3dsmax but nothing helped. Do you have any solution? Maybe it’s some Phoenix parameter that I should adjust… I don’t know! Help me please. My deadline is approaching. ​
Hi, thanks for posting. Have you set up your Grid as open in all directions? There is a second streak of foam that looks like it is bouncing off of the grid?
Yes, The grid is open in all directions. For me, the problem is at the bow of the boat. Do you know what I can do so that the simulation doesn’t get ahead of the boat?
Note that the boat hasn’t even touched down yet and the interaction with the foam and splash is already happening
Here is a nice tutorial about the same setup you are trying to build. Please check it until we get back to your thread.
Hello. I already followed this entire tutorial. And this is happening in my simulation. It looks like the simulation is in front of the boat. The error only appears when I add the foam and splash.
Hi, could you check you input roll out? Is it possible that you have changed some settings there like the ones in the screengrab below:
