Hi guys,
Anyway that I can remove the spill color of a flooring wood for a specific object? I mean, I would like to remove the spill color from the floor(yellow) only for the ceiling and walls(white).
The problem to use a white color on the reflect in CoronaRaySwitch map is all my glazing is showing the floor white for obvious reasons. So, I wont affect the glass reflection if it makes sense.
Thanks a bunch!
I may not have fully understood the problem you have but by any chance the video I am attaching below provides any solution to your issue? If not, can you please elaborate your issue? Maybe a screenshot could help me understand what you are trying to achieve.
In case, you can not share your scene+images here, then you can also contact us via ticket. Submit a support ticket -
https://support.chaos.com/hc/en-us/requests/new
Hi Avi, thanks for the video. It is solved. I don’t know why it was not working before.
