[solved] Phoenix FD Wetmap invisible in material editor
A quickie: does it work?
Does corona somehow utilize the Phoenix FD Wetmap… if so, how?
It should work as long as “Render-time Only” checkbox is disabled in the Particle Texture map. Can you confirm this, or let me know if there is some other problem?
Thanks, I saw this info from you in an older thread… what I can’t actually figure out is how to find that Particle Texture Map? Sorry!
Sorry. It looks like you need to enable “show incompatible” first. This should be definitely fixed.
Ah! Very sneaky! That’s a new one for me… many thanks. I’ll report back how I go. Cheers
Works flawlessly! Thanks.
I simply plugged the Particle Texture Map into a corona mix, made one texture a bit darker and voila!
Sweet, glad to see it working fine for you!
(Report ID=CRMAX-147)
For anyone interested, I tried my hand at tutorial creation focusing on using a wetmap in Phoenix and rendering a steamy sauna with Corona.
https://youtu.be/RmnYR_WGiHY
My first tutorial, so please go easy on me
