Hi. Can’t make the camera render a full 360 panorama. But it doesn’t render a full sphere, there seems to be missing a bit of the 360. Here’s what I’ve done:
Created a free-camera (max-standard), and set lens to 35mm. The camera has no rotation on X & Y, but is rotated -45 degree on Z (to make the startup view correct).
Applied a CornonaCameraMod to this camera, and activated (checked) “Override: Spherical” in Projection Type. Nothing else changed.
Set renderoutput size to 1600 x 800 for testing purpose.
Any ideas what’s wrong or missing?
BTW - Using Corona v1.00.02 and PanoramaExporter v0.3
Hi DeadClown. The Z-rotation is in World-coordinates, so its not the tilt angle (?). I’ve attached the test image, so you can see whats wrong. I’ll try to set Z rotation to 0, and check again if there should be something wrong with my spherical HDRi.
Hi. So I checked the HDRi - nothing wrong. I set Z rotation to 0 (world coordinates) - nothing changed. Checked (again) if CoronaCameraMod was set to Spherical - yes it is!
So in the next test I made a spline-sphere centered around the camera (Blue lines are 0, 90, 180 and 270 degree, and red lines are 45, 135, 225 and 315 degree). As you can see in the attached render, there’s clearly missing a bit of the panorama - about 60-70 degrees.
Tried restarting max, and fresh scene without any changes. But I might have found something: Tried to render both Spherical and Cylindrical and both are giving identical result. Not just regarding “cutting of”, but exactly the same result.
I’m not using daily builds, so is this a bug in v1.00.02? Or should I try to uninstall and reinstall Corona?
Edit: I attached the scene, so anyone (romullus?) with 2014 can try to see if they get identical result - or maybe someone can see what’s I’ve been doing wrong
