Ok, so if I get my camera settings (iso, fstop etc.) just how I like them and render out a “spherical camera” image at 45 degrees, it comes out fine.
If I change the 45 degrees to a 360 degree render then all I get is a completely black render. Something obvious I am missing? I have tried to use default camera instead of physical cam but if I do that I get a render that is totally overexposed. Changing the GI multiplier does nothing.
Any clues?
Re: Spherical camera image
use 359 instead of 360. Since it’s a “physical” camera, and 0 degrees is equal to 360 degrees, you can’t have two physical things in the same exact place. (I know, this sounds really stupid) You should be fine.
Hi dkendig, thanks for your reply. Actually I got it to work after I posted this. First I rendered out an image at 355 degrees and it worked, so I changed it to 360 and re-rendered and it worked perfectly.
So just to re-test I quit out of sketchup and reloaded my model - tried 360 and it failed again. tried 355 and it worked, then changed to 360 and it worked fine. LOL!
At least I found a work-around, thanks for your suggestion at that works fine too.
Hey,
i was wonder if Rhino does have this option too: physical camera + 360degrees view.
Could you answer?
no, vfr doesn’t have that ability yet, you have to use the standard camera.
And will it have? hehe
Thanks Dkendig!
yup, once we bring the new plugin core over to Rhino, it will have all the features V-Ray for SketchUp currently has. IES lights, ambient occlusion, new procedural texture types, etc.
