Pictures say it all - not sure why everything is shifted, but this is unusable in its current form. Will try side by side and confirm if thats a-ok
Does the issue reoccur after switching back and forth between Standard and VR Spherical Camera modes? Do you remember any of your actions prior to producing this output? Switching on/off GPU Acceleration or any Render Output parameters?
Would you be able to save a .vrscene file of the scene and send it over at support@chaosgroup.com for investigation?
Regards,
Peter
Messing around with a couple settings. Something is definitely awry. BTW, I’m running the newest 34004 from Aug1 (win10), and don’t remember as many problems with the previously compiled one. Some sort of error with install?
UPDATE:
reset settings and everything seemed OK. Not sure what the issue was, but I’m guessing its related to our vropt file we use as defaults. Maybe safe frames?
Sending over vrscene and vropt that we use as default shortly
Thank you for your reply and for supplying us with the requested files!
A ticket for this issue has been logged and should hopefully be resolved by the time for the next release.
The latest build is completely identical to the previous one with the same version number (3.40.04). Therer was a specific change in the installer which would affect a very limited number of users who had trouble installing the previous build.
Kind regards,
Peter
I have the same issue. VR Cubemap does the same thing. Seems to fix when you reset but after tweaking all your settings, a reset is painful.
The issue is due to duplicating stereo settings. We suspect it has occurred on scenes which have been worked using different V-Ray versions, possibly the 3.4 beta builds. This should not be reproducible in the upcoming update.
Kind regard,
Peter
