Status bar on VFB half hidden
Just wonder why the status bar of my frame buffer is partially cut off from the bottom of the window?
Not a really a pain but I’m having some time to start fixing things around..
Do you happen to be using the environment variable VRAY_VFB_UI_SCALE ?
Thanks Peter,
no, I haven’t use this one. Where is it accessible, so I can check the assigned value?
Based on your screenshot, I assume you are using a 4K dispaly. The current VFB design was not originally designed with such resolutions in mind.
This can be amended by creating a system environment variable used to scale its interface. The “Environmental Variables” options are available through the ‘Advanced system settings’ window (or simply type in “Environmental Variables” in the Windows Start menu).
Create a new one called VRAY_VFB_UI_SCALE and try a value of 2 or 3.
Kind regards,
Peter
Works! Thanks.
