Still Can't Match View with Two Point Perspective in SketchUp
Hi Guys,
I’m in a time crunch and again I’m at a point where I need 2-point perspective to match the rendered Enscape export exactly. Please don’t say this is an issue with SketchUp, because this is possible, and can be done, we had to do it with V-Ray, it can be done with Enscape.
Bug:
  1. Create a new scene with some architectural object.
  2. Add two point perspective view.
  3. Pan or zoom to desired viewpoint location.
  4. Open Enscape with “Synchronize View” enabled and Capture> Resolution: Custom “Use Viewport Aspect Ratio” enabled.
Result:
The rendered result do not match the SketchUp view port. You can see the results below.
Please let me know if I’m wrong, or if there’s a workaround I’m not aware of and I understand the time it takes to fix something like this, but it really needs to be resolved correctly. What I see in Enscape export should match exactly with what I see in the SketchUp viewport when these settings are enabled. If you need contacts at SketchUp to help fix this, I can put you in contact with the right people. If you need to know how V-Ray fixed this issue I can put you in-touch with the Dev who made it work (now at Trimbel with the SU team). But it needs a solve, and it needs it quickly because i dont want to constantly have to revert back to other programs when things like this occur.
@tedvitale.cg Enscape is not supporting view sync for panning/zooming while two-point-perspective is active in SU. You have to “break” the two point perspective in SU by rotating the camera a lil bit (reactivating the two point perspective) and then the viewport should match.
We’ll check the feasibility.
Yes, but if i break the view I loose the client approved perspective. This is an important one if you want users like myself to jump off the V-Ray train. You have to match the viewport every time if the control is designed to match the viewport. It cant just be when its convenient. Again, If you need help (i know its a pain in the ass) I know the guys who did it already and might be able to help.
This one is my biggest challenge in these days. Especially, when I need an rendering in eye-level and have to correct the vertical lens shifts… as @tedvitale.cg mentioned, eveything goes well before you switch the 2-point and pan to higher… I have to imitade the correct skp perspective in enscape with no synch mode and select the architectural two-poin pers. on. But this time you can not adjust the field of view perfectly, also in this way, you will get different images everytime and previous photoshop works goes for nothing. Because you can not get the exact same image…
Yeah, I can feel the struggle. We will check it.
Any news on this? I’m still struggling to get the two point perspective sync to work…
Yeah guys, we know its not the easiest thing to implement, but it is a huge frustration.
same here!
When I was using a trial of Thea render a while ago I believe that it could match the renders with the views after panning.
