Hi! I´m trying to render an sketchup scene of a building make whith two point perspective in sketchup 2018 and doesn´t work in enscape. ( the vertical offset is incorrect)
There is any simple way to do this ?
The preview
image is atched
Thnaks!!!
Hey @VARQ , thanks a lot for your post. ![]()
When “Architectural Two-Point Perspective” is turned on, “Synchronize Views” cannot be enabled, thus you’ll have to manually adjust either the camera height through Enscape (“E” to go up or “Q” to go down), and/or adjust the “Field of View” in the Enscape Settings - General tab accordingly.
Since the FoV is different in SketchUp and not being synchronized with Enscape itself (which it would be if “Synchronize Views” is on), the output of the viewport is not identical to that of Enscape, even when you’re in the same scene in both SketchUp and Enscape.
I hope this helps. Let me know if you have any further questions regarding this subject.
Thank you very much!
i think this is a problem for me becouse i need to save this “two point” correction inside enscape view to anoder renders , and in this case i think it can´t be done ok?
@VARQ , that is correct, I’m afraid, this is currently not possible. But generally, could you briefly elaborate your workflow when it comes to transferring our Enscape views to another renderer? ![]()
I think I found the way to do it. So before setting your view, adjust the field of view to 0 or 1, and save as a new scene.
I don’t if thats what you’re looking for, but for me when I have to do kind of 2D still plans I can use this work around. And get rid of the perspective.
I also really hope these can be synchronized someday! I often use overlays from Sketchup to create more sketchy renders, so it’s nice to have the views line up and low angle two point perspectives are very common for architectural renders.
+1 as I have brought this up as a huge bug - not a missing feature - a bug as without this ability, camera matching is a broken feature as far as I am concerned. Architects NEED 2pt perspectives.
The best work around is setting your views in Enscape and not SketchUp.
Again - that makes it a bug and not a feature. Some of us use sketchy styles and composite them in post.
100%!! This is such a basic feature it’s hard to understand why it’s taking so long. Please let us match ALL views. I know you all are working on parallel, please make sure this doesn’t get left out from that update.
again, it matches the perspective not the 2 points, so enter a value of 1 instead of 50 for example and you’ll have it. @andybot
The problem is when you pan the 2pt view in Sketchup. See the example at the top of this page.
I know, but its not a problem if you assume that Enscape does not work with 2 point perspective, thus using the 1 degree for the field of view. its only a matter of entering the value instead of switching to 2 point perspective. But I understand that it works better with plans
@benjaminriendeau I’m not sure we’re talking about the same thing. Sounds to me like you’re talking about matching “parallel” view. I’m referring to 2pt perspective.
How do you adjust your scenes ? in escape or in sketchup ? and all your aim is to render image in 2 point perspective ?
I m adjusting all my scenes (with 2 point perpesrctive or not) in sketchup using a ‘’ safe-frame plugin ’ and then opening enscape and adjusting the aspect ratio in visual settings matching in safe- frame plugin.
When I do that ; even I do not have to syncronize the views , I am just rendering the image adjusted on sketchup side.
believe me the only way is using a sketchup safe frame plugin.
@devrim_topuz - look at the first post Two point Perspectives in Sketchup - that’s what happens when you pan in a 2pt perspective view in Sketchup. The views do NOT match up.
I am aware of it. all you need to do is just '‘disable view synchronise’'and then ‘‘synchronise the view’’ the after you pan.
What I recently did was set my shot in Enscape, turned on 2 point perspective and then saved a view. A tab get’s created in SKP without the correction but when you sync the view and it will show up in Enscape incorrect, but when you turn off sych, the enscape view get’s the 2 point correction.
