I have 2 Maya open.
I render with 2 Maya (to test multiple materials for example). But when i press “echap” to stop my render on 1 Maya, the render will stop on all Maya.
Is it possible to stop the render on the “focused” Maya ?
I have 2 Maya open.
What do you mean by “echap”?
We couldn’t reproduce the issue in here. Does the issue persist if you stop the rendering with “Esc” button?
Which V-Ray for Maya version is that?
“Echap” is “Esc”, so the problem is always here.
My Vray is : V-Ray for Maya version 2.20.01 from Feb 1 2012, 17:09:48 Maya 2011 win64
Perhaps it is corrected on nightlies builds.
I will test on a nigtly to see if i have this same little problem.
We reproduced the issue.
But most probably it is a Maya problem instead. It can be reproduced with MR as well.
It looks like it is a Maya QT problem. I haven’t the souvenir to have this bug on Maya < 2010, but i will retest.
So, it is not important. Do not take time to resolve this problem.
Thank you.
autodesk does not intend for people to work in 2 applications at once ![]()
