Im doing an yacht simulation just for fun and learning purpose.
On the right side of the boat the foam makes this strange issues
despite in the preview it works fine.
Do you know what might be?
On the left side everything is ok…the boat is symmetrical…
There are no hidden objects etc. etc. We did many test but no way to change those artifacts…
Are you using any Count multiplier above 1 in the Particle Shader by any chance? If you do - how about if you set it to 1?
Does the issue reproduce if you hide the foam and leave only the water?
Btw - is the yacht mesh a closed one (in order for the simulation to work properly you need shelled geometry with no single faces, no open edges, no overlapping faces) ? If your run an STL check modifier over it - there should be no errors.
You can either attach them here through a google drive, dropbox or a similar service or if the files are private you can submit them through the support system here - https://support.chaos.com/hc/en-us
There is a button at the top right “Submit a request”.
Hi , i have a problem with Vray Denoiser for animations , i have this scene with a boat in the sea and a phoenix simulation , i exported the frames in exr format and i followed the tutorial to activate Vray denoiser for animation , when i open the denoiser tool pannel everything it’s okay and i chose the file for denoising operation, it reads the files correctly but the denoiser doesn’t work the animation it’s still grainy , how can i resolve that ? i’ve been missing something maybe . i need some help if it’s possible thanks.
