Hi, I found a strange behavior and was searching for hours (!). It seems the symmetry object just mirrors 1 object of the hierachy.
See the example attached. In the editor you see 3 cubes mirrored. But in the rendered image there is just 1 cube mirrored.
My workaround is either use an instance (instead of symmetry) and scale it by -1 OR use the connect object to combine the different objects together before using symmetry.
I have now many workarounds for different issues of vray5 and I wonder how much wasted time I’m spending in these workarounds..
sym test.zip (52.1 KB)
