test on glass and juice
hi :slight_smile:
here is a simple test scene.
all comments are welcome.
Simple my *** :shock: Beautiful render and nice design :wink:
really nice
What glass material did you used?
Congrats :lol:
nice glasses:)
Hi Giraffe,
Very nice, especially the green one. The juice looks like it has substance - particles and pulp. Very good. :slight_smile:
very nice renders
Well, very nice indeed. I watch your work with great jealousy!
As someone involved in fluid dynamics I notice these trivial things in other peoples work. The average observer would not see it I think.
The area of the rendering where the fluid surface meets the glass is called the meniscus. it regularly forms a concave surface at that point of contact. Think of that surface as an elastic surface. It sort of sags under it’s own weight.
In section (or profile) we see a very slight up-turn as if the liquid wants to “crawl” up the side of the container.
In renders this can be something that gives the overall effect of added realism.
me·nis·cus
n. pl. me·nis·ci (-ns, -k, -k) or me·nis·cus·es
The curved upper surface of a nonturbulent liquid in a container that is concave if the liquid wets the container walls and convex if it does not.
Nonetheless, your work is beautiful. I do not want you to think I am critical.
Naomi
great!
the metal reflection on the green one could use some mor glossines
The green image is fantastic. Haven’t seen juice rendered that good before.
Marc
Very nice renders!!
Can you tell us a little more about your juice material.
Nice materials and the glasses are awesome.
love this glasses…very nice render :smile:
Super super i love the first the second is good too but i think is to much dof in my taste the juice liquid is also fantastic! Good work!
hi friends :slight_smile: thanks a lot …
blueplanet: thanks a lot for information :slight_smile: but my english not enough to understnad the details :frowning:
here is wireframe:
and juice settings are:
diffuse: grey 139
reflect: rgb 245,173,114 fresnel on
refract: noise map
fog color rgb 241,204,146 fog mult:0.03
translucent: white
thickness: 180
light:30
it’s looking extremely well.. If you could couple the first and second image, metal from the first and juice from the second, I’d be happy. Love the tequila sunrise feel of your second liquid.
I don’t think I’d actually want to drink from the glass though, unless I had in writing from the producer that the handle is properly attached to the glass with a third component, like glue.
The handle doesn’t seem to reach far enough around the glass to keep it in place, glass should be slighty conical aswell, but this is only me going detail-crazy.
The renders look good that’s the real issue.
cheers,
K.
Yep !
The orange juice is Fabulous !! pulpe and staff great !! i like it…! :wink:
I like them very much
:sweat_smile:
..but I think the glass need to be more dense especially at the bottom (where the glass has more thickness ) like gijs if I remember well on some glasses
Is only my little opinion
But anyway are great images
:wink:
Nice Work Giraffe
Hey really nice work. like that one with the green background.
That yellow one really looks nice. really juicy juice :stuck_out_tongue: . Great renders and glasses :lol:.
Regards,
Thanks.
Inxa
@Giraffe: you speak german, right? Then I will try to explain in german language what blueplanet has meant:
Du solltest berücksichtigen, dass Flüssigkeiten eine Gewisse Oberflächenspannung etc. haben. Wenn Du Dir ein Glas Wasser genau anschaust, wirst Du feststellen, dass der äußere Rand der Wasseroberfläche leicht nach oben geht.
Hab zwar nur ein schlechtes Bild ergoogeln können, aber hier sieht man das Phänomen am eingetauchten Finger:
http://www.howellschools.com/~voyager/staff/3rd%20Grade/stension2.JPG
Hier noch eine Zeichnung dazu:
http://mlucom6.urz.uni-halle.de/~laagz/Image102.gif
Ein kleiner Nebeneffekt davon ist nämlich, dass es dann so aussieht als wäre die Wasseroberfläche vielleicht 1-2 mm stark wenn man von außen (von der Seite) auf das Glas schaut.
I think that is what blueplanet has meant.
:slight_smile:
Mirko
hi again :slight_smile:
thanks again for replies…
I am sorry I dont know german :sweat_smile:
Giraffe,
Excellent renders!
Evelyn
