anyone had a problem with RTT stating that “system exception occured during render” using Vray RC3?
does anyone has a solution to this problem?
/Ryan
/Ryan
are you exporting out as a vraycompletemap?
yes, i used vraycompletemap
max cannot initiate baking the texture, thus giving the error.
i used it with no errors in RC3, how much memory is your computer using when it crashes?
i have 4 gigs of RAM. max uses only 783MB.
Could it be the multi/sub map that causes the error?
