I’m using the latest V-Ray for UE 4.26. I have a scene with several 4K textures and I’d like to do a draft render on my dev machine. However, I’m facing out of memory issues when I try to render this particular scene.
I tried circumventing this issue by setting the Textures mode to ‘Resize’ instead of ‘Full’, however V-Ray throws an error both in CUDA or Optix render modes.
When I use CUDA, I get the following error:
PTX build error 218, error message ptxas application ptx input, line 22; error : Illegal modifier ‘.uni’ for instruction ‘mov’
ptxas application ptx input, line 73; error : Label expected for argument 0 of instruction ‘call’
ptxas application ptx input, line 73; fatal : Call target not recognized
ptxas fatal : Ptx assembly aborted due to errors
And when I use Optix, I get the following error:
[VUtils::VOptix::OptixModuleCreateThread::proc] OptiX error encountered in vray_optix7.cpp[943]. Error Code 7200
The same errors happen when I try the ‘On-Demand’ mode.
Are there any workarounds or fixes for those errors?
Thank you.
