We are looking into replacing our workstation laptop. We are looking for top performance in Revit and Enscape in VR. Take price out of a answer.
GeForce 2080 RTX with max-Q
or
Quadro RTX 5000
thoughts?
or
Quadro RTX 5000
thoughts?
Looks like the Quadro will be about 50% faster: https://gpu.userbenchmark.com/Compare/Nvidia-RTX-2080-Mobile-Max-Q-vs-Nvidia-Quadro-RTX-5000/m704710vsm712800
That comparison might not be entirely fair, as it compares the laptop specific 2080 max-q (which means it’s clocked down to reduce heat) with a desktop Quadro RTX5000. However if price isn’t critical absolutely go for the Quadro as you’ll have a lot more memory, which always comes in handy in large scenes or when rendering really high resolution screenshots as well! :thumbup:
well, it really depends. If You create scenes which consume ALOT of memory, then the quadro will have an advantage. but, if the scenes can fit on both cards, the performance should be almost equal (as the cards are based on the same chip). if money is not a problem, then the quadro will be more future proof (due to the extra memory), but in daily work with normal scenes there should be no noticeable difference.
