Totally wrong glass effect on 2.4.2
the glass material on 2.4.2 shows basically no any translucency,and reflect only background hdri map(outdoor) only.(yes,I have already set the
quality panel to Ultra and did not work at all)
really disappoint to your debug abitility.
Hey @whiteanne77 , thanks a lot for your post and welcome to our forum! :slight_smile:
If you want to add translucency to your material, please reduce the Opacity and set the Tint Color to white. Also, I would recommend you lower the Refraction Index, to, 1.52 for example, which would be the index of real window glass. This should allow you to get the appearance you’re looking for.
Further, regarding the reflections, please be so very kind as to also check out our following FAQ article explaining why you have missing objects in your reflection. Real-time reflections in general involve finding a good mix between performance and rendering output, in addition, be assured that we’re constantly in the process of improving them even further with practically every release.
I think there’s an idea that I can give you as a reference for how to get the right specular reflection, which is when you render, you specify only certain faces that allow you to get the right specular reflection, not all of them, as lumion did when he added the reflector
Because more and more people are actually suffering from poor specular reflection
Or add a default material, only for mirrors, and limit the number of faces (for example, 10) to get accurate reflections
whiteanne77,
Perhaps you should take some time to understand how to use materials in Enscape before criticizing the developers in your first ever post!
https://enscape3d.com/knowledgebase/sketchup/
foggo:
I totally know how to set the glasses material okay…and the translucent materials looks normal on previous version! It did with something error in the currently version.As my opinion, I just report the bug with my duty as an user!
3
(attached photo was render by 2.4.1.42
Hey @whiteanne77 , thanks for your further post.
In this case, would you please be so very kind as to send in the project at hand so that we can have a look at it for comparison/troubleshooting purposes? :slight_smile:
Thank you very much again in advance.
@whiteanne77
I just looked at your material and the way the parameters are, that’s basically obsidian. It may have worked previously for you, but that was more or less a bug.
What you want is something with less opacity.
Right:
Left
The tint works on top of opacity. It’s basically Tint + (Opacity * Color). Generally unless you want something very specific, it is advisable to either use tint or color and opacity.
Further, you probably don’t want this value for roughness.
Hi there,
I’m having some issues with getting glass to appear translucent from Sketchup.
Can someone please tell me what I’m doing wrong :slight_smile:
I’ve dropped the opacity but neither the escalator nor falls arrest glazing is appearing translucent.
Thank you in advance!
@stlgreen make sure both sides of the glass are the same material.
