Turn off Ambient Occlusion?
Hi
Is there a way to turn off/down the Ambient Occlusion in Enscape? I´m trying to render some interior white walls and the AO is really making it look fake:(
Can you share a screenshot of that?
The AO we use is rather subtle and shouldn’t be a hindrance when it comes to creating realistic renderings - because of that a screenshot would be very helpful to see the scene setup.
If you are using non pbr compliant white, it will be more obvious.
If you are trying to do white walls in an interior , try making sure your value or brightness for the colour (B) in the HSB mode for material colour in SketchUp is below 90
I tend to use 80 for a white painted wall( 204,204,204 in RGB) - it will look a little dimmer, but it will render better overall.
It’s the Ambient Brightness Slider, right? The default is 50%, but turning it all the way up to 100% will eliminate ambient occlusion (or turn it down significantly). Personally, I usually go the other way, turning Ambient Brightness down to like 10% or less because it makes the shadows and contrast feel more realistic on interior scenes. The default is washed out and lacks definition. It will make the scene much darker overall, but you can turn up the exposure or artificial light brightness slider to bring it back within an acceptable range.
