I haven’t used phoenix FD for a while and am trying to use it on a project for a quick, basic, tyre burn smoke effect.
I’m following a max tutorial (https://www.youtube.com/watch?v=cM46wtfPynk) but i’m using phoenix fd for maya (3.1)
The effect is a close up of the wheel with the tyre spinning very fast and the smoke spinning around with the wheel. I have a smoke emitter cube with the smoke set to volume inject and then another source (spinning cylinder) with the wheel rotating using ‘motion velocity’ ticked. However i am facing two main problems:
1. I want to run the sim, then adjust, then run it again. Every time i start again it runs the same sim. If i hit delete- IT DOES NOT DELETE! The sim just jumps to the first frame of the last sim. This is soooo annoying. How do i stop this? Ideally i don’t want to cache at all, i just want a fresh sim every time i start from the beginning, like with maya ncloth etc.
2. The motion velocity source doesn’t seem to be effecting anything at all. How do i check if it’s actually having an effect on the sim? I want the rotating tyre to spin the smoke around, i have a spinning wheel with motion velocity set to 1 and it doesn’t seem to have an effect.
3. If i change the scene scale between metres, centimetres etc this seems to have no effect whatsoever also. Is there a reason why this is? Maybe it’s because i’m still running the old sim, I can’t tell because I CANT DELETE IT!
sorry for the CAPS folks, you can see I’m on a deadline!
Thanks in advance for any advice!
