I made some waves hitting the shore and it seems that after a sec or so there are some dark areas appearing. I cant seem to figure out why. I attacged a snippet of the animation - it appears in the last part of the snippet. Anyone have any suggestions? It is calculated with 800.000.000 voxels.https://youtu.be/7FOoXnnr7F8
Hey, could it be that there are gaps appearing between the shore geometry and the liquid mesh? You can check this in the viewport preview.
Cheers!
Thanks for your reply - Unfortunately that is not it. Any other suggestions? It seems to dissapear over time. I can upload a longer sequence if you want to check it out.
Thanks,
Yes, please. Can you also show me a still frame so we are sure we are on the same page?
