I’ve been asked many times what are “good” V-Ray settings. Of course, there is no universal answer and it depends on the desired render speed and quality, but here is a set of settings that I have found to work very well for still images in many situations. Please note that these settings are not optimal, in the sense that with enough tweaking, you can probably get similar quality with faster render times. The beauty of these settings though, is that they require almost no tweaking and you are guaranteed to get a nice result in the end.
Provided that you start with a default V-Ray renderer:
(*) In the Image sampler rollout, switch to “Adaptive DMC”.
(*) Set the “Max. subdivs” to 100 (one hundred). Leave the “Min. subdivs” to 1.
(*) Set the primary GI engine to Brute force GI. Do not change the subdivs.
(*) Set the secondary GI engine to Light cache.
(*) Set the light cache interpolation samples to 5.
(*) Set the DMC Sampler “Adaptive amount” to 1.0.
(*) Un-check the “Clamp output” option in the Color mapping rollout.
Typically you will need to adjust the Noise threshold as the default produces too much noise. A good value is 0.001 for V-Ray 1.4x, and 0.005 for V-Ray 1.5.
(*) You are done.
To control render quality vs render time:
(*) Adjust the DMC Noise threshold. Lower values reduce noise, but increase render times.
(*) Adjust the light cache subdivs. This is scene dependent, but usually values from 1000 to 5000 are enough for most scenes. You can also adjust other light cache parameters as necessary.
(*) Turn on or off reflective/refractive GI caustics as needed.
(*) Optionally turn on the “Use light cache for glossy rays” option to speed up glossy reflections.
(*) You may want to adjust the render region (bucket) size for faster feed-back.
Notes:
(*) Leave all subdivs anywhere at their default values. They won’t have any effect anyways - the 100 AA subdivs will almost certainly override everything else.
(*) For builds of V-Ray before 1.49.30, DO NOT use color mapping other than Linear. Otherwise, you risk to get an incorrect result in the end. If necessary, apply color correction in post. You can change the dark/bright multipliers, provided that you leave both at the same value. For V-Ray 1.5 and later, you can use whatever color mapping you want, provided that “subpixel mapping” and “clamp output” options are both off (which they are by default).
(*) Avoid using sharpening AA filters. They can make the noise more apparent.
Advantages of these settings:
(*) Very little parameters for controlling render quality.
(*) Work for a very large number of scenes.
(*) Typically produce high-quality results.
Disadvantages of these settings:
(*) May be slow to render. With tweaking, you may get faster results.
How it works:
The high AA subdivs essentially causes all the sampling to be performed by the image sampler. It will take as many samples per pixel as required to achieve the specified noise threshold. In many ways, this is similar to PPT, but is done on a per-bucket basis and the number of samples is adaptive.
Examples:
Here are some examples which have all been rendered with these settings, with minor differences (GI caustics on or off) and Noise threshold of about 0.001: Chaos: Industry-leading design and visualization software
As you can see this method can also render GI caustics quite well, although they may take quite some time.
vlado its a bit unclear what light cache interpolation samples to 5, is it in screen space or in world?
also why 100 max samples? I remember you saying that 1/5 is more then enought? has this been changed?
This is as you wish. Like I said, you can change the light cache parameters according to your needs.
also why 100 max samples? I remember you saying that 1/5 is more then enought? has this been changed?It is enough for AA, but not for things like GI and glossy reflections, especially if GI caustics are involved. With these settings, V-Ray will take as many samples as necessary to get to the specified noise level, so you need to make sure there are enough samples.
from the tests i just manage to sort out with this "univesal render settings"in the interiors i get slight better rendertimes, but much more noise than with my previous settings… :roll:
if i try to reduce the noise rendertimes go way up…
Well, like I said, they are not optimal settings; it’s very likely that you can get better render times with less noise under different settings. However, they are universal in the sense that you can just load a render preset, hit render, and know that you will get a good image.
Yeah… this is a very clever way of looking at adaptive sampling, and it seems to be a good method. It probably will work well when dealing with things like animation involving geometry change and light change. By minimizing the variables, it makes it easier on the user adjusting the settings. I don’t think Vlado is dismissing other methods of doing the GI such as IR maps, etc… those are still very valid. Nonetheless, I think I will redo my sun light test with this method and see if I can reduce the very fine noise.
I haven’t had time to test it yet, but could you please confirm, Vlado, that glossy based speculars will resolve properly even by leaving the settings to their defaults on the materials?
I noticed that raising the subdivs in glossies tends not only to clear the noise, but also to define a lot better the actual shape of the highlight, especially when some anisotropy, or the ward method is used.
Would the AA take care of that too?
Wouldn’t it just clean up an “incorrect” result?
Yep, glossies will be fine and correct. However, this also means that because of the unclamped colors and lack of color mapping very thin hilights may appear somewhat jagged. There is no way around this unfortunately, as it is the correct result.
this is my result using this system. they are awesome i have to say!
This test is with the vray sun/sky system. I had to put the noise to .0001 to get this clean. rendertimes are average of 1 hr/frame. http://throb.net/vray/qmc\_test\_sky.mov
This is using Debevec’s timelapse HDR sequence and the vray dome system. I did not have to get the noise as low. .0005 worked here so the render time is faster naturally at avg of 33 min/frame. http://throb.net/vray/qmc\_test\_timelapse.mov
end result is that the gi quality is awesome and man those renders are CLEAN. nice work.
