USD import in Maya do not load Vray Materials in VRay 6 update 2
I’ve been able to load USD files form 3D Max in Maya with all the Vray material in Maya 2022 with Vray 6 update 1.1
Now with the update 2 if i try the same method all that i get is the default lambert assigned to all the geometry
Do i need to change anything in Vray when i import them??
best regards
Roberto
Seems to work fine on a fresh setup. Have you set the “Plugin-In Configuration” to V-Ray in the USD exporter (prior exporting to USD)? No need to change anything on import.
I’ve deleted the Maya user folder to delete all preferences
and in one computer with the 2023 versión, Vray 6 hotfix 1 I get all the vray material correct (i`ve to correct some of the Vrayplugin nodes, but this is not a problem)
In the same computer Maya 2022, Vray 6 update 2, all that I get is the USD preview surface materials
in another computer Maya 2022, Vray 6 update 1.1 the Vray materials loads correctly
In all cases is the same file exported from MAX with the Vray export option​, i import the file in all cases with a drag and drop, but no matter if i import the file with the maya file browser, the result is the same
Could you attach the scenes and USD file so we can review them?
If you prefer to that privately please go to the support contact form.
I`ll send you the files using the support contact form because the files are big
thanks
Roberto
