I have a UVW Randomizer with “Random by instances” on a cloner in symmetry object. If I switch of the symmetry everything is fine. If I switch the symmetry object on, the randomizer doesn’t randomize.
Is this an expected behaviour or an error? Thanks
Hello @haniel1107 , Thank you for reporting this. I was able to reproduce the issue on my end, and it has been logged with our Development team under VC4D-2865. In the meantime, I’ve found that using “Random by Node Name” produces the correct result, so you can use that as a workaround for this project.
Thank you @daniel.kapsazov , I thought I tried this, but apparently not. Thanks…
