Hi, I found a texture-issue if I work with instances. The logo of the company is on a planeobject with uvw-mapping. The original is ok, but the instance is flipped.
Cheers
Tobi
Hello @steilvorlage.de ,
Can you please send us a simplified test scene where this issue can be observed? Also, please specify the exact versions of V-Ray, Cinema4D, and the GPU driver that you have installed. Does this issue only happen when rendering on GPU or does it also happen if rendering on CPU?
