V-Ray 7 for SketchUp, update 4 is now available!
It can be downloaded here:
download.chaos.com
A complete list of all new features and improvements is available in the Release Notes
Regards,
Konstantin
download.chaos.com
Regards,
Konstantin
Veras is now part of V-Ray, enabling AI image generation, AI image post processing and video generation
Veras can be started from the V-Ray / AI submenu, the V-Ray toolbar, VFB toolbar and history context as well as from the Asset Editor
Sending viewport screenshots or renders for AI processing is supported
Chaos Cloud licensing is implemented. Migration from the License Server workflow is automatically performed by the installer
Changing the licensing method after installation is possible via the “Change V-Ray license settings” utility tool
Installing and managing the Chaos License Server is no longer necessary in the new Cloud licensing workflow. Active account licenses can be viewed in the http://my.chaos.com/licenses control panel
Drag and drop of multiple image files directly in the Asset Editor and Node Editor graph is now possible
Node Editor: Toggling between Glossiness and Roughness in the V-Ray material now correctly updates the input labels of the material
Light Gen now uses auto-exposure for all classic Light Gen HDR scenarios. Note that the automatically calculated EV is translated to an editable camera EV value on application
Various AI Mood Match UI labels are updated for better clarity
An issue with downloading the Mood Match environment textures when a .lighset file is loaded, is resolved. The loading progress bar is improved.
The material Displacement attribute is no longer labeled as “legacy”
A “Utility” option no longer appears in the Texture Placement Type dropdown after setting a UVW Placement as a mapping source
An issue with the Gradient map’s preset dropdown is resolved
An option for disabling all AI features is added in the installer
A new way for managing the Vantage viewport rendering resolution is implemented. When Vantage 3.3 and later is used, V-Ray’s render output resolution is used for the viewport stream
Enabling Scatter Cluster Painting during interactive rendering no longer makes the Scatter instances to disappear
An issue with changing Multi Material inputs during interactive rendering is resolved
An issue with the Scatter viewport preview when removing Scatter from an object after toggling it off and on, is resolved
An issue causing a freeze when Scatter viewport preview is enabled in specific scenes is resolved
An issue with the applying Scatter during interactive rendering is resolved
SketchUp no longer crashes in specific situations when Scatter is toggled during interactive rendering
An interactive rendering issue caused by changing object’s material and then transforming it is resolved
An issue with toggling the Use Mtl Override parameter of Cosmos assets during interactive rendering is resolved
MacOS: An error message no longer pops up after installing V-Ray under macOS Tahoe 26.4.1
MacOS: An issue with the animation output in SketchUp 2026 is resolved
Vantage is no longer closed after SketchUp closes when started as a child process
