V-Ray 7 render problem - Error building Embree static ray caster
Hi everyone!
I decided to upgrade to V-Ray 70004 but whenever I try to render I get this error message, for both CPU and GPU rendering. I want to note that the rendering works if there is no mesh in the scene, as soon as I add any mesh the render stops and I get this error. I also want to add that my previous version was V-Ray 62006, and everything worked fine.
I also attached the screenshot of the error, this is just a blank scene with a dome light and a cylinder added, no changes made to settings.
Does anyone have a reason or fix for this?
Thank you.
It was discussed here https://forums.chaos.com/forum/v-ray…84#post1217584
Yavor​
Thank you very much! It is fixed now.
