When I’m trying to render a scene there’s always an error and it fails. I have tried with other files and also with a new project and every time the same error appears, the errors started when vray was updated and in other pcs it worked correctly. I’ve seen in other forums that the error might occur because of RAM, but in this case the other pc had less ram than the one I’m trying to render.
Error
\[V-Ray] Embree: Failed to allocate RTC\_GEOMETRY\_TYPE\_TRIANGLE
Error
\[V-Ray] Building Embree Box Tree failed: \[EmbreeBoxTree::build] 2: Creating new scene failed
Hello @alejandro_pea ,
Thank you for reaching out to us.
Please Reinstall Microsoft Visual Redistributable: https://learn.microsoft.com/en-us/cp…-2019-and-2022
Download and install the X64 Search - Microsoft Bing version.
Once installed please restart your machine and try using V-Ray in a new scene and let us know if the error is still reproducible.
Hello @natalia.gruzdova
I just tried to Reinstall Microsoft Visual Redistributable, but it still won’t render the error still is happening. Tried it in a new scene.
Hello, have you restarted the PC?
If this does not help please download embree-4.3.3.x64.windows.zip from this website Release Embree v4.3.3 · RenderKit/embree · GitHub
In the bin folder locate embree_info.exe file. Start Command Prompt (type cmd in Windows Search) and drag&drop embree_info.exe into the command prompt window and click Enter. (Video example)
Note that if the RDRAND line is missing (see here the example) it means that your best option is to upgrade your BIOS. Please share a screenshot of how it looks on your side.
Hello, yes I restarted the PC.
Here is the screenshot, and the RDRAND line is missing so I’m gone try updating the bios.
How are you?
I’m having the same issue as Alejandro and I’ve reached the prompt. I’m not sure how to update the BIOS. Can you help me?
Still having this message:
Hello @leticia_spezia ,
I apologize I missed your message.
First of all, could you please update to the latest V-Ray 7.10.00 (link) that was released recently and check if you are still able to reproduce the error?
Also please note, that BIOS update is necessary only if the RDRAND line is not present in the prompt.
