Vray 7 embree static ray caster error
I getting this whenever I try to use v-ray 7, CPU and GPU version
[15:56:30.980] Error : Error building Embree static ray caster, error message: [CommitEmbreeThread::threadProc] 1: Committing scene failed
[15:56:31.164] Error : 1 error(s), 0 warning(s)
It happend wenever I add some geometry to the scene, for example a scene with one light renders fine, but when I try to add a box or sphere the render stops and shows this error
v-ray 6 works fine
It happens wenever I add some geometry to the scene, for example a scene with one light renders fine, but when I try to add a box or sphere the render stops and shows this error
v-ray 6 works fine
Do you run the V-Ray 7 installation through some script or some other automated way ? In general we’ve seen this error on machines with quite old Microsoft Visual C++ Redistributable. By default V-Ray installation installs the required version and everything should work correctly.
Can you try reinstalling V-Ray ?
Yavor
I have reinstalled V-Ray on both 3ds Max 2024 and 2025, but unfortunately, the issue persists. No automation scripts were used during the installation. I’ve ensured that all drivers, Windows updates, and 3ds Max itself are updated to their latest versions.
Let me know if there’s anything else I should try.​
Hm after installing V-Ray the redistributable is located in Program Files\Chaos\V-Ray\3ds Max 2025\utils - vc_redist.x64.exe - can you try installing it manually. Also try restarting the computer altogether.
it worked! thanks
Glad to hear that.
Sorry to revive a thread from a few months ago, but we recently began having this same error on some of our studio machines.
It actually seems like if you have the most recent version of the C++ redistributables installed (14.42.34433.0​) from something else pushing them, V-Ray 7 can start kicking this error. The version of the C++ redistributables that is with V-Ray 7 is older (14.40.33810). If you uninstall the newest version and install 14.40.33810, it works.
That would make it seem like the error will begin repeating itself whenever the software that originally pushed the newest update forces it again.
Same Issue with myself. Since I updated to Vray 7 a Max file won’t render.
RAM is not the issue.
I also encountered the same problem. My own computer has no problem, but I helped others to solve this problem. The system is Windows 11 and it is a newly installed system.
i’ve just run into this same issue on my machine. since restarting this morning i can no longer render when there is any geometry in the scene.
[15:27:21.885] Error : Error building Embree static ray caster, error message: [CommitEmbreeThread::threadProc] 1: Committing scene failed
win11, ​C++ version is 14.40.33810 (which should be fine according to the post up thread…)
for anyone else experiencing this, updating to c++ 14.42.34438 seems to have fixed the problem.
we have started seeing this error on multiple machines in our studio on both 3ds max and sketchup.
both have the C++ version 14.42.34438 as above
both users affected were able to render this morning but are unable to now.
both can render an empty scene, but as soon as adding any geometry the render fails.
have updated to latest vray version for sketchup and 3ds max and restarted but still getting the same error message.
i am able to render the same scene on my machine without any issues.
to my knowledge there haven’t been any updates pushed out to either machine.
we found a workaround by turning off embree in sketchup settings / optimisations
is there a way to disable embree in vray for 3ds max?
toggling ‘conserve memory’ has no effect.
looks like a new version of embree has been released by intel (v4.4.0) last week - might that be causing a conflict with Vray?
have also tried installing the latest stable nightly build 33051 for max 2024 but getting the same error.
UPDATE - we have managed to resolve the issue by uninstalling the last few C++ distributable and manually running the Vray distributable located in Program Files\Chaos\V-Ray\3ds Max 2025\utils - vc_redist.x64.exe
i assume that whenever a new version of the C++ distributable is pushed out it may cause issues with Vray and throw up the embree static raycast error.
not ideal, but at least we have found a fix, although it does mean going through the same process on all of the machines in our studio.
If you go to programs and features, select the version of C++ you have and select modify. Then there is an option to repair. That’s what works for us. Again not ideal but our solution. Very similar to yours.
Anyone know which versions of C++ are causing this issue and if there will be a fix from Chaos? Was this caused by a corruption in a C++ update or something else?
It’s not that it’s corrupted, it’s just an older version. Usually, software that utilizes C++ Distributable always installs it together with the main software (like V-Ray does), so it’s possible that certain installers still use an older version, therefore overriding our own.
I’m also getting this Embree error from V-Ray7.00.04 with 3dsMax2024.2.7.
Issue started in early April 2025.
I fixed it with VC_redist.x64, but now the error is back.
Details:
In April, I had error on local workstation (Windows 11) and render farm nodes (all Windows 10, farm via Deadline 10.4)
I installed VC_redist.x64 on all machines, following instructions here, by Tsvetomira:
Material preview missing after updating to V-Ray 7 - V-Ray for Rhino :: Issues - Chaos Forum
Unknown to me at the time, the download link was for version 14.42.34438.0, which is higher than version: 14.40.33810 (which ships with V-ray 7.00.04)
Regardless, the error was fixed on all machines after I installed 14.42.34438.0.
Now fast forward to May 2025:
Over the last week, a few render nodes have started giving the Embree error again. E.g.
2025/05/21 11:32:22 ERR: [17308] [13788] [V-Ray] Building Embree Box Tree failed: [CommitEmbreeThread::threadProc] 1: Committing scene failed
In add remove programs, 14.42.34438.0 is still present but I see no sign of 14.40.33810.
It must have never been installed with V-Ray???
Just to confirm, I am installing V-Ray manually.
I assume I should now install 14.40.33810 (which ships with V-Ray) on all machines and hope it sticks?
Thanks,
Graham
