V-Ray 7, Update 2 Hotfix 2 available for download
V-Ray 7, update 2 hotfix 2 is now available for download from our website for 3ds Max 2021-2026
Build 7.20.04
Date – Sep 11, 2025
Bug Fixes
[/HR]
V-Ray
  • Considerable rendering slowdown in Compact material editor and Slate material editor
  • VRayProxy preview is incorrect when scaling or previewing an animation
  • VRayCryptomatte does not work if material / object / layer name (depending on the ID type) contains “=”
  • Crash in V-Ray GPU when resetting 3ds Max after rendering an animation with Daylight system
  • Slight shift in Night Sky stars position when rendering vrscene on different OS
V-Ray GPU
  • The Night Sky is partially visible on a random occasion
  • Night Sky renders with black artifacts when VRaySky is set as map to VRayLight type dome
  • Extended rendering capabilities for a number of gaussian geometries along a ray
VRayDecal
  • Decal displacement not working with constant black texture in V-Ray Standalone
V-Ray: Bitmap to VRayBitmap converter
  • MaxScript error when running the Material Library Processor
