V-ray Clipper with Phoenix FD
I have a quick question, I’m hoping someone could answer for me. I’m trying to test the V-ray Clipper with Phoenix FD and so far I noticed that the clipper works fine on the actual simulation box (in this case the liquid sim). However, I noticed that the clipper does not work on the foam. Not sure why it won’t work on the foam or if there is something I could do to get this to work?
Here is an image that shows what I’m testing. Dropbox - Error - Simplify your life
Thanks,
Dani
i’m not familiar with the clipper, but in every case of different behavior of the foam and the liquid, you can try eventually to fix it switching the foam in geometry mode.
That worked, Thanks for the help! :slight_smile:
