V-Ray for SketchUp 2.00.25244 available for download
Hello everyone,
V-Ray 2.0 for SketchUp SP 3 is now available. SketchUp 2015 now has a 64 bit version that this V-Ray service pack fully supports on both Windows and Mac.
Please, find changelog below.
V-Ray 2.0 for SketchUp Change Log (build 2.00.25244)
New Features:
- Support for SketchUp 2015
- V-Ray for SketchUp now writes out colorized textures
Fixes:
- Fixed issue where environments using HDR would be incorrectly gamma corrected if the “Correct LDR Textures” option was enabled
- Fixed issue that could cause VFB to lock up and require ctrl-alt-del to be pressed
- Fixed issue where bloom mask was not working during DR
- Fixed issue that caused tangent space normal mapping to not work properly
Updates:
-Relative paths are now supported for bitmap textures.
OSX version (MAC) shows 32 bit, where is the 64 bit for Mac OS X? Is misplaced? Why we have only 64 bit Windows? Can you fix the error in the download area? Many users still waiting for the 64 bit OS X.
Thanks.
It appears to be fixed now
You guys do a cracking job, this though “V-Ray for SketchUp now writes out colorized textures” has made such a huge difference and deserves thanks alone. I know you could achieve the same thing via the Vray material editor but its so much simpler being able to do it from within sketchup.
