V-Ray Next Update 1 hotfix 2 available for download (Next 1.2)
V-Ray Next Update 1 hotfix 2 is now available for download from our website. Here are some highlights:
  • Support for 3ds Max 2020.
  • Added support for Substance 2 maps in V-Ray GPU and Chaos Cloud.
Full change log:
New features:
(*) V-Ray: Initial support for 3ds Max 2020;
Modified features:
(*) V-Ray: Support for IES files containing the comma (“,”) symbol in the light’s description;
(*) V-Ray Cloud: Add support through baking for Substance2 textures;
Bug fixes:
(*) V-Ray: Blowup and Auto Region Selected produce stretched results;
(*) V-Ray: Crash when exporting vrscene to a non-existing directory;
(*) V-Ray: Direct light selects are always propagated through refractions;
(*) V-Ray: Drop action should fall back to default;
(*) V-Ray: MaxScript error occurs with viewport menus when V-Ray is downgraded to an older version with no viewport IPR support;
(*) V-Ray: Separate VRayCryptomatte REs names are not exported to .vrscene;
(*) V-Ray: Wrong keyframes export to .vrscene, breaking animation rendering;
(*) V-Ray GPU: Viewport IPR has wrong perspective when switching the active viewport from orthographic projection;
(*) V-Ray GPU: VRayDenoiser is not always applied on the complete pass;
(*) V-Ray GPU: VRaySamperInfo render element is not exported;
(*) V-Ray GPU: Wrong Object XYZ texture mapping for Volume grids rendered;
(*) VFB: Color corrections panel is missing when is maximized during IPR session;
(*) VFB: Lightness color correction with values close to zero lead to artifacts in Lens Effects results;
(*) VRayPhysicalCamera: Vertical shift is reset in the viewport preview;
(*) VRayProxy: “Expand # to frame number” doesn’t work in the viewport;
(*) VRayVolumeGrid: Volume grids loaded from OpenVDB caches that contain internal rotation render clipped with V-Ray GPU;
(*) .vrscene exporter: Crash when trying to export vrscene to a non-existent folder;
(*) .vrscene exporter: Decimal separator changes randomly on every export in a specific scene;
(*) Installer: Silent uninstall does not work for V-Ray Next;
