Hey guys, this is mostly a question about vray in general, but I did not see a general Wishlist topic.
do you have plans to implement scenes within scenes? For example:
-You import a few vrscene files from Maya max to 3DS Max (note that this can be any software, from max to sketchup for example).
-You create the rest of the model in Max.
-You want to export this model for example to Vantage.
- When you export the new VRScene file, the VRScene files within them are not visible in vantage.
It would be great if they could work together? Or at least enable to go one level deep. I understand that if this is enabled, you could export vrscene within scene within scene etz… But at least one level would be great.
Hi Chaos group team we work in an interior design office and we like to modeling our detailed 3d assets at 3dsmax since we can achieve a more realistic quality in our models however we render our project at Sketchup since we can make shop drawings straight out of our 3d models also we would like to start using chaos vantage to have a faster render result however in our workflow this is not possible yet since vantage can’t read the Sketchup Vray scenes with other Vray scenes in it coming from 3DSMAX really appreciate if you guys could have this feature as soon as possible then we could implement vantage in our workflow
of 3dsmax Vray moidels inside a Sketchup Vray scenes
As far as I understand, vray cloud uses the same thing. So it exports a vrscene file and renders it, BUT it does recognize scene within a scene. But vantage does not for some reason.
This is a major problem at the moment. If we model something in sketchup. We have to manually place all the models in vantage again. That is extremely time consuming.
I would like to contribute to the significance of this topic as well. Specially now that vray 6 for rhino understands enscape models and materials, vrscenes is becoming the format to communicate between platforms and render in vantage.
Even though i can import vrscene in max and render with VRay, or merge in Vantage standalone, 3ds max vantage live link does not read the vrscene.
I agree that this is very important. I use vrscenes as xrefs to do various lighting scenarios and different foregrounds for the same model and keep those in separate scenes. Lack of vrscenes support is the only thing preventing me from primarily using Vantage (which is AMAZING)
I too would like to contribute to the significance of this topic as well. As a Sketchup, Vray and Vantage user it would be great to be able to import pre made vrscene files objects into a larger vrscene file opened in Vantage. Vantage is incredible and saving me time in so many ways. Keep up the great work
Adding additional vrscenes in Vantage is currently possible. You can use the FIle>Import or drag’n’drop the vrscene in the viewport. Then you can filter what to import from that scene - lights, materials, geometry, cameras. You can do this multiple times.
We are currently in development for the support of this feature and it will be available later this year.
Hey man, sorry to bump this one again. The request has been made 2 years ago. Any info on when we can expect this?
At the moment we have to manually re import all of the vrscene assets used in sketchup again in Vantage. It is REAAAALLY time consuming. We can’t even use the live link because of this, the items are just not there at all.
BUMP. This didn’t make the cut for 2.0 then? I have a scene with VRscene objects within it, but when I export that ‘master’ scene to Vantage the VRScene objects don’t show up.
