I have a simple question..
When putting a sun, should i “overide the sun’s parameters”(meaning i put a little V in the box) OR Not (no V in the box). I’m using Vray for Rhino.
Thanks to all
Re: V_ray sun parameters in Rhino
Hi Laurent
When you have a check mark that mean that you can override the sun parameter. The problem is that this option doesn’t work on the environment rollout. If you want to override the parameter you should disable these option (uncheck the boxes) and change the parameter through light properties.
Best
Thank you for your answer! You are doing a terrific job for all the users! Keep going!
