Vantage 3.3 command run
Vantage 3.3 supports command-link rendering, but we have encountered a problem. After a render job finishes, the Vantage engine has to be terminated and restarted before it can process another job. The currently running engine does not accept additional render tasks sent through the command-line command interface after completing the first task.
Expected behavior:
The running Vantage engine should remain active and continue accepting new render tasks without requiring a restart.
This is how the command line works. It’s the same as vray.exe command line rendering.
The very command launches the rendering GUI and then shuts it down. However, it takes 7 to 8 seconds or even longer for Vantage to start up its GUI.
