Vantage High Resolution Renders Error
I am not able to render very high resolution renders in Vantage.
The render snapshot shows memory error though I have two RTX 2080Ti installed in my system (image attached).
Also, when I enable denoiser, the rendered image looks odd when the size of the image is large (image attached). But when rendered in smaller resolution, it renders normally. Is there a limit to the output resolution?
Please help me sort this issue.
Hi basafath21,
Chaos Vantage currently doesn’t share memory between multi GPUs so that is why you are seeing the warning for not enough memory. If the output can fit in a single GPU’s VRAM it will render out correctly. We are looking for a way to improve this.
This is a bug in the NVidia driver which we have reported and only occurs on high resolution renders(5000x3329 as the lowest resolution that fails, 5000x3328 is OK) as you have noticed. Currently there is a limit of 16384 x 16384 but that is not related to the denoiser issue. We are in waiting on NVidia’s side to fix the issue. What driver have you currently installed?
Alexander
More specifically, this bug occurs at resolution 5000x3329 or higher. It was supposed to be fixed by an Nvidia driver release last month. Which driver are you using?
Currently using Nvidia Grahics Driver 471.41
Can you please update to the latest driver (496.49 ) and see if the issue continues?
