Is there a way to make the VFB appear when you click the Rendered Frame Window icon, instead of the standard Max one…?
(Running Max 2009 and Vray 1.5 SP5 here at work)
While you can’t replace the action of the RFW button, you can easily add a button to bring up the V-Ray VFB - right-click on the main toolbar and click Customize, then from the Category drop-down select VRay, and drag the command called “Displays last rendered V-Ray VFB” to the toolbar of your choice. This will add a button called “V-Ray VFB” to that toolbar - when you click it, the V-Ray VFB will open.
Great. Thanks Vlado. Is there a way the installer could do this automatically? No big deal, either way.
(I bet I’m not the only one hoping you rebuild Max, one button at a time. :))
