Hello, yesterday I was trying to match an aerial photography using a vray physical camera. After tweaking all parameters including horizontal and vertical shifts and hit the render button, I found that what it was seen in the viewport didn’t match with the rendered image.
I’m using Windows XP 64-bit, 3dsMax 2009 SP1 64-bit, Vray 1.5 SP3a 64-bit.
I attach both images.
Vlado, if you want the 3dsmax file, plesae give me a email address and I’ll send it to you.
nop, but after finding the problem I was trying every parameter, changing from cuadratic to cubic, changing to perspective, then to standard camera, etc… but no positive result
i think i remember that the physcam FoV could not be EXACTLY matched in the viewports.
That’s due to its accurate lens simulation.
Again, if i recall right.
that, plus a lens-distortion software.
The standard camera at least doesn’t add lens distortion to the cg stuff, so you only have one distortion (the one in the picture/footage) to compensate for.
PTLens seems good a tool to do that.
