Vista
Has anyone been able to get Vray spawner 1.5r3 to work with a render node in Vista? I can’t get the it to start.
You may need to use the “Run as administrator” option.
I got it working, but ive since removed vista for other reasons and I cant remember what I did. It may have just been the run as admin that was it though.
Thank you for your replies.
The “Run as administrator” option does not seem to work. I get the following error: The procedure entry point sdbget AppCompatDataSize could not be located in the dynamic link library apphelp.dll.
In order to get it to do this I change the properties to Windows XP comatability mode. If I don’t make this change nothing happens.
How odd; is this the 32- or 64-bit version of Vista? Any service packs installed?
32 bit I installed the most recent updates and still nothing.
I got it. I use VIZ and forgot about the vrayspawner.ini thing.
Ah, ok. I’ve already modified the spawner to look for 3dsviz, if it cannot find a 3dsmax file, so in future builds there will be no need for the .ini file.
Thanks for being so attentive Vlado.
