Volumetric Fog Density Map - NOT WORKING
Hello, I hope I am posting this in the correct forum.
I’ve spent all afternoon trying to get the texture map for the Volumetric Fog Density to work.
I’ve tried changing the mapping coordinates, applying noise texture, checkered texture, and scaling the texture and cannot seem the density to change at all.
I’ve tried using it with and without a box gizmo and still nothing.
I feel like it is either an issue with the program or something wrong that I am doing.
This link says I should just be able to plug a noise texture into the density map.
If you can post a stipped-down scene with your fog settings I can take a look at it and help you.
I got it to work on a new scene!
