Is anybody else noticing VR performance issues after installing the most recent few versions? Models that i used to be able to do virtual tours in just fine are no longer working smoothly.
just as a note, running rtx 2080 super
Not lag related but we have issues with teleporting not being responsive; it often doesn’t work on the first click. Teleporting works fine and is very responsive on .exe files created prior to 2.6.
@ParkerOubre , please kindly make sure that you’re using the latest graphics card drivers provided by NVIDIA. If that doesn’t help, then lowering the “Rendering Quality” in the Visual Settings → General tab probably helps, right? Which Quality have you setup generally to be used with Enscape VR? ![]()
Since RTX support has just been enabled, outdated graphics card drivers could explain the worsened performance - please keep me posted!
@rifkin , sorry to hear about that. So in this case you experience this even when the experience is very smooth performance wise? Did this occur after installing our latest update or also before?
I did a quick test with an export from 2.6.1, teleport seemed to work fine. Maybe it was fixed with the update, or just an issue with a particular file. Will keep an eye out if it happens again.
Glad to hear about. Keep me posted! ![]()
