Vray 1.5 and Viz2007 not working - SOLVED
I just tried to install Vray 1.5 on Viz2007. After installing 1.5 I fired up
Viz and I got about 10 different “plugin failed to load” errors, all vray
related. When I go to the assign renderer tab in Viz there is no vray. Is there something else I should be doing ?
Btw..I installed our copy at work on max 8 and it worked fine.
Any help needed urgently.
Regards,
Mike
I must be retarded. :smile:
I uninstalled and reinstalled and it is working fine now.
Please disregard my stupidity. :stuck_out_tongue:
Mike
LOL…you scared the crap outta me! Don’t do that!!! ROFLMAO!
Phew, I nearly had a heart attack here… I’ll rename the thread to indicate this has been solved.
no, no…vlado, you were supposed to rename it “…due to my stupidity” LOL
sorry mike, had to say it! hehe
LOL.
Sorry guys ! :sweat_smile:
I think that I must have used the wrong path when first installing. (Autodesk folder instead of viz folder for the root mabey). I was in the middle of something with my kids.
I must say that the new color mapping type “reinhard” is most excellent
when used with the proper gamma correction. And I used the Vray sun and sky at work today for the first time. The project is residential houses,
interior and 4 exteriors. The results (compared to direct standard light)
are simply amazing. Chaos has outdone itself once again. I certainly have
alot more features (ones that I can actually use on a daily basis) than I
expected when I purchased Vray.
PS…My wife is a photographer. Im going to get a crash course on cameras. She was pretty impressed with the new Vray camera.
Again, sorry for the confusion.
VRAY WORKS WITH VIZ 2007
:lol:
Regards,
Mike
:lol:
I thought I heard Vlado scream from here :shock:
:lol:
“I felt a great disturbance in the force. As if a thousand Viz users cried out in terror and then were silenced.”
@mmikee: What is the proper gamma correction? You are using Rheinhard in conjuntion with LWF? Sorry no 1.5 yet to test it myself…
I would assume he means changing the new “gamma” spinner to 2.2
The tests ive done with Reinhard, i just ticked sRGB on the VFB and saved the Img over riding the default gamma in the save window from 1.0 to 2.2
LOL LOL LOL :lol: :lol: :lol:
