Hi guys, I need to finish a little work before update to Maya 2012, but the question is: How can I do run Vray 2.0 in Maya 2011 Subscription Advantage Pack?.
Searching in the forum, I saw the way to do it, but with Vray 1.5, the next process:
Install Vray for Maya in the next three directories:
a)Suscription Advantage Pack Maya’s root
b)Suscription Advantage Pack Maya’s root/vray/plugins
c)ChaosGroup’s root folder.
Then, copy “modules” folder, from prior installation to the root of Maya 2011 subscription advantage pack and edit the file leaving "VRayForMaya.module as:
// Module file for Maya. Helps Maya find resources for VRayForMaya.
+ VRayForMaya2011x86 0.9 C:\Archivos de programa\Autodesk\Maya 2011 Subscription Advantage Pack/vray
For the last, establish next environment variables:
VRAY_FOR_MAYA2011_MAIN_x86, C:\Archivos de programa\Autodesk\Maya 2011 Subscription Advantage Pack/vray
VRAY_FOR_MAYA2011_PLUGINS_x86, C:\Archivos de programa\Autodesk\Maya 2011 Subscription Advantage Pack/vray/vrayplugins
Finally, launch Maya and find vray plugin, throught plugin manager in (mayaroot/vray/plugins).
All right, but I still continue having this error:
// Error: Cannot find procedure “vrayUpdateAE”.
What am I doing wrong!?.
