VRay 5.2 VRscene No support for AA Image Filters
Currently there is no support for Cubic, Quadratic, Sharp Quadratic (and some other image filters) when exporting vrscenes. Are there plans to add support for these filters or is there a workaround to get non sharpening filters to work with vrscene?
Yes, that’s because they are not supported in Standalone. I am unable to say if there are plans for it. Why do you need exactly those filters? Tell us your scenario, maybe there is another way of achieving it.
We have been using the Quadratic Filter for a while now as it’s one of the few filters that don’t have built in sharpening. We found that some of the filters that use sharpening cause issues with tiny spec hits and moving cameras. In general when sharpening is desired, we do it in Nuke. I don’t have an example ready as we haven’t done any tests lately unfortunately but if we end up doing more tests, maybe we can build a scene that I can share.
The vrayLanczos filter has no negative components, and so it doesn’t sharpen (and it’s *much* quicker than quadratic to render, as an added plus.).
Fireflies are -mostly- a thing of the past, and in any event you shouldn’t ever need to try and cure those via filtering, as it can quickly get exceptionally expensive (as much as each different kernel, and the energies at play, demand.).
If they come from bugs, we should be fixing them, if they come from scene setup (i.e. visible sun disk on Chrome shader), they should be fixed changing the setup itself.
If you have a scene which requires quadratic to render correctly, we’d be very interested in obtaining it to study it and see if we can improve on our side.
Ah well maybe it is time for us to re-evaulate it then. Thank you for your insight.
My understanding when reading graphs like these: https://en.wikipedia.org/wiki/Lanczo…zos-kernel.svg
Basically the x axis is the radius from the source pixel and the y axis is the amount of influence it has to the current pixel. It was my understanding then that at x ~= 1.25 the influence was negative, which is basically sharpening. Is this understanding wrong?
Another thing to consider, that I would have to test, how Lanczos handles data channels that are filtered? If it actually does create negative values, the way I think, maybe that’s something we had issues with?
You are absolutely right.
However the V-Ray specific implementation lacks the negative component of the graph, and as such is *sharp*, but not *sharpening*.
It shouldn’t at all, lacking the negative part, but of course feel free to test it around overbrights/HDR values, to see if you spot any ringing.
N.B.: Far from me to diss softening filters: they have great use and can make for exceptionally filmic-looking renders. It’s just they are expensive, and there may be much cheaper alternatives for daily use. :slight_smile:
Thanks so much for the explanation. Sounds like it is time for us to switch to the faster and improved filter :slight_smile:
