VrayLanczosFilter and VraySincFilter
…anyone have info on the Vray AA filters? …are they sharpening or softening filters? …do they render faster than standard AA filters? …etc.
The sinc filter is a sharpening filter, while the lanczos one is a smoothing filter. They are neither particularly faster nor slower than the standard filters, but may look somewhat better (although this is very subjective).
Do you still advice to “Avoid using sharpening AA filters. They can make the noise more apparent” when using “universal” vRay settings ? for example Sinc one ?
Of course; there is nothing to be done about this - after all, the exact purpose of sharpening filters is to bring out the color transitions (noise included).
Which filter to use depends a lot on what kind of picture you’re rendering. for instance doing something like architectural viz you’d usually want to use a sharp filter and sometimes even edge enhanced (though I don’t recommend that) however if you were to go for a natural look then a smoother one is better. Also if you are doing animation you will get much more flickering when using a sharp filter. I usually use the VRaySincFilter but it’s just a taste thing
Sharpening filters also have a nasty habit of causing serious edge artifact when you have bright areas like a high reflections of a light source or sun next to a darker area. This was not an issue before real world lighting. However, because in Vray everything is rendered in float (with 0 being black and 1 being white) the bright area could be a value of 5 and the dark 0.02. The sharpening filter will get you an “error” at that edge actually giving
you negative values basically looking like a nasty black edge.
This can actually be avoided by using a smoothing filter and, if sharpeing is needed… do it in post.
