having an official vray batch render would be great or at least integrating it to the existing max batch render when one uses Vray frame buffer.
Fernando
Fernando
whats wrong with the max one with vray, works fine?
if you use vrayframe buffer and you save an exr from there with elements is different from max output files…maybe i’m wrong but is what i get.
if you render with BB nad save the VFB through the file, renaming the VRIMG extension to EXR one, youll get one multilayered EXR which you can open in programs that support it …or you can split the rendered chanesls in the VFB rollout if you want.
