VRay Blend and Blur Utility Material
Im currently working at prime focus with vray for maya and max, im doing some ldev in max on some shaders using a blend material
For each blend i want to add a bump map on them and then plug that blend material into a new blend and then add a bump
This seems to work fine in maya using the vray bump material but in max I have been using the Utility Material from blurbeta and its giving me what i need sofar
But when i come to plug my blurbeta Utility Material with a vrayBlend in to a new vrayBlend and then add a new coat, the base material in that vrayblend doesnt seem
to show up or render
It won’t work… we really need to do the VRayBumpMtl material in 3ds Max too. Let me know how urgent it is and we can bump its priority.
I would really like vray to work with the blur utility material. :slight_smile:
It’s actually the other way round - the blur utility material needs to be modified so that it is compatible with V-Ray. Can’t do much about that, I’m afraid - unless we had the sources for it so that we can modify it and recompile it.
Ok fair enough - do you see any likelyhood of Vray getting a material of this kind?
