VRayBlend Material limitation?
Just found that the Vrayblend material doesnt like a top/bottom material as the base material.
Is this a limitation? or a bug?
VRayBlendMtl can work only with V-Ray compatible materials, since it uses V-Ray’s own internal shading API rather than the 3dsmax one. So it will not work with the Top/Bottom material right away, but you may be able to simulate that with another VRayBlendMtl and a suitable blending map.
But VRayBlendMtl doesn’t work with VrayLightMtl…
And it’s not easy to build some simple mask pass…
any idea
From spot3d helpfiles
VRayBlendMtl is specifically designed for the V-Ray shading API and can only support V-Ray compatible materials (VRayMtl, VRayFastSSS etc). Additional V-Ray compatible materials can be developed with the V-Ray Shading SDK.
:wink:
smartarse
:wink:
are you sure? I’ve used the VrayLightMtl in a VrayblendMtl, although not as a base material.
I find it ‘quite’ a useful way of generating a self illuminating material with vray. Or realy just making it brighter…
I use blend material as a blend max material…
I use it as a sort of maya’s layerShader
I prefer using only vray stuff into my renders… instead of max stuff… It’s an old habit from maya + MR stand alone…
Here is an example without color correction:
www.kdgnet.net/demo3D/Fabien/Douglas/TestCoupe002.mov
Here is an example with color correction:
www.kdgnet.net/demo3D/Fabien/Douglas/TestCoupe003.mov
I use a vrayBlend for the teeth shader…
And for colour corection I need some mask to calibrate each material separately…
Thats why I override with a max blend to have self illum colours…
Best regards
Edit : Sorry the second link was wrong… Now it’s fixed…
Well, it does, in newer builds which you can get if you email me to vlado@chaosgroup.com
